I'm sure that this has been answered before, but what are people running for cold pressures, front and rear, running the 225 Hoosiers on a 2nd gen RX7?
Thanks for the info.
Rory
Rory
Rory,
It would be a dis-service to you to answer without knowing camber, caster, spring rates and shock valving.
AB
Andy Bettencourt
06 ITS RX-7
FlatOut Motorsports
www.flatout-motorsports.com
[This message has been edited by ITSRX7 (edited January 21, 2003).]
I realize that other factors play into the equation.
So, Andy, what camber, caster, spring rates, shock valving, and tire pressures are you using?
Rory
We have a few cars on the team but Nick's was developed to it's current state:
650lb F 375 lb R
Camber is track specific
Valving is custom for 'up to' 700lb rates
My car should look like a typical ITS RX7:
500lb F 325lb R
Stock Koni valving (max spring rate for this
valving)
Our Hoosier pressures were in the 36 degree cold. This showed us the best pyrometer readings at our tracks. We now run the GoodYears.
AB
Andy Bettencourt
06 ITS RX-7
FlatOut Motorsports
Andy,
Thanks for the info!!
Anyone else agree/disagree?
Rory
Live by the pyrometer, Obi-wan. Everyone will be a little different.
AB
Andy Bettencourt
06 ITS RX-7
FlatOut Motorsports
Andy is right. Tire temps tell the tale. I run a softer spring/shock setup and my pressures for Hoo Hoo's are a bit lower than what Andy runs.
Pauly D
