Help:will I be racing this weekend at Nelson Ledges?
I thought I was in the final prep. stage. While my wife was hitting the brake pedal and I was attempting to bleed the system, we could not get any significant pressure. Additionally, there was a unusual "whooshing" sound coming from the engine bay and the reservoir had large bubbles when the pedal was depressed. After repeated attempts and amplified emotions I noticed a small puddle under the booster and master cylinder. The fluid is running down the front of the booster (the paint is comming off). I have a new master cylinder in my spare parts bin and I have a new booster special ordered and ($173) arriving tomarrow afternoon.
Does anyone have experience with what I have described?
Any diagnostic strategies?
Does this problem sound like the cylinder or the booster?
Any tips on removel and installation of these parts?
Problem 2
Assuming, I can solve my brake problem, I have installed a fuel cell, new braided lines, and a Yaw Carb. I read further in his directions and I need to advance the timing to 27 degrees. I have not messed with the timing on a rotary engine. I have a standard Craftman timing gun. Any advice would be really helpful since panic is setting in.
Thank you.
Bill Emery
ITA#23
