Originally posted by rlekun:
Okay, related question. When you run the exhaust under the rear axle, are you doing anything to keep the axle from dropping on the exhaust when jacking the car up, or do you just let it hit it? I've seen guys put a steel cable around the axle that's attached up by upper spring perchs...
Whoops, thats not technically legal. Not being a nerd here,just helpful. you can limit it legally, just run your limiting cable from the top of the shock to the eye at the bottom, therby invoking the "any" shock rule
