Originally posted by Domino:
Rally type shifting (WRC type stuff) is different because although the shifter is taller so it's closer to the driver's hand, they use sequential short-shift transmissions. Thus the "throw", if you want to call it throw, is about a 1/4".
If you lengthen the shaft of the shifter on a traditional rod/cable transmission, without adding a short-shift kit, you will greatly increase the throw and also increase the chance of missing a gear.
i didn't think about how long the throw would be with a very long shaft on the shifter. thanks for the info!
