I need a 40mm QUAIFE for a 1990 crx
Dave Volante
515-229-0054
Dave Volante
515-229-0054
The differential bearing size for the transaxle you have is 35mm. I just did a installation of a Quaife in a '90 CRX L3.
You can use the tapered roller bearings and use the diff with the 40mm journals but, the 35mm ball bearings make things very easy. The ball bearings are available at any good bearing outlet. I think the number is 6205.
apparently it varies from one car to another.
IE: one 1990 crx Si can be 35mm, another 1990 crx Si can be 40mm. Best to measure your tranny
Chris is right.
And you can get them from Quaife,
http://www.quaifeamerica.com
But, crap! They aren't on sale anymore. Sure wish I had the money when they were.
Jon
