Originally posted by jc836:
Did I read you reply correctly-that the stock intake tube goes outside. That is not how mine lines up under the hood directly above the radiator tank. As to a CAI-they are not legal for ITA or I might have done something to bring air up rather than block off the opening in the pan (required).
One of these days I will get dyno time and will determine if there is a power improvement over stock.
Under the IT rules, the air intake is open before the throttle body or metering device and can exit the confines of the engine bay through "stock" openings as long as no "ram air" effect is created. So, in the interpretation, the AEM CAI on a Honda CRX si in ITA is legal as it requires no modification to the body, is before the throttle body and does not create a ram air effect.
