I need a little help getting the right parts for my '86 CRX Si ITA car.
Cooler
-what size dimensions
-how many rows
Sandwhich Adapter
-20x1.5 or 22x1.5 I've seen both referenced for Honda applications
Size of lines
-8 or -10 ?
Clayton
Cooler
-how many rows
Sandwhich Adapter
Size of lines
-8 or -10 ?
Clayton
22x1.5,-10 lines and a 19row oil cooler.Call me i,can get a good deal on the coolers
Bob
Bob,
Do you retain the factory stock oil-to-water heat exchanger and screw the adapter between the heat exchanger and the filter, or do you remove the heat exchanger and just use the sandwhich adapter ala 1st gen carb'd cars?
Get me a price on the oil cooler when I see you at the BRIC.
P.S. If you see Tim B. ask him if I can borrow his spare carb'd distributor before the CAT National so that I can continue to troubleshoot my tach bounce problem. Thanks!
