honda civic hb
i have a spare 91 honda civic body and was wondering where to start. im looking at itc. also, will i run into any probs with tech because i used to have a dx 1.5 5-speed in there, but because of its accident history, its sort of a pile of parts put together...no si stuff and im swapping in the spec 4speed 1.5 for itc...anything to watch out for...or tips??? need help, thanks.
The 88-91 Civic HB is listed in ITC but you need to be VERY sure that the collection of parts that makes it to the track (including the VIN number) are all from Hondas of that vintage and of the specification original to the ITC-listed model of that car.
You may have already done this but, if not, order a copy of the GCR (rules book) before you spend any more $$. If you are starting with something that isn't "all there" it might be an expensive proposition to get it back to original specs, so proceed accordingly.
Best wishes with the project!
Kirk
yes !! Same as above! Get the GCR. basically the car must be using the original spec parts.
