What are some good pressures to start out with for a Victo v700? 84 ITB GTi. This will be for my first race at NHIS. Thanks
84 ITB GTI
84 ITB GTI
Hmmmmmm. I'll be running there also with my GTi. Maybe you should start with 60lbs all around. That should slow you down enough!! Just kidding!!. My first year with the car, so I'm looking for the same info.
Jeff L
#74 ITB GTi
I think about 35lbs. on all four would be good to start. Then after driving it you can make apropriate changes.
Doug
87 Golf GTI
[This message has been edited by Racescort (edited March 27, 2004).]
I run a 83 GTI with the new compound V700, you want them coming in up around 40, anything lower and they will blister and seperate, I kow, I lost 3 tires thinking they were like the older compound.
I started with 33-34 front and 35-36 in the rear,depending on temp. seem to work the best.
I do run a welded diff so that may make a difference with your front pressures.
Hope that helps?
Jeff L,
Is that Tommy’s old car? He should have some good starting points. or now that I think of it did he ever run Kumhos ? or just Hoosiers
HHMMMMM
Then again maybe you should take your own advise and try 60PSI.... that way Eli or I can get in front of that car(without it on 2 wheels)
Matt Bal
Yup, that's Tom's old car. He ran Hoosiers. They still had some life on them til I roasted them at a PDA event last week!! I don't think you have to worry about me, I'm still figuring out how to run a FWD!! Although it was pretty sweet in the rain! None of the tail wagging I'm used to.
Jeff L
#74 ITB GTi
For your first race while still learning the car I think you'd want to set the car up as neutral as possible. While you're on your Novice Permit trying to get your races in the winning set up isn't what your looking for, consistent driver improvement is. As someone who is midpack, I'm still learning the car and as a driver. After chasing the elusive hot set up in my second season of racing, I decided to heed the advice told to me many times over. Set the car up to be predictable and evenly balanced while working on your race skills. Instead of screwing around with the car I went out with the "average" set up and ran an enduro at VIR last February. By the time the first MARRS race at Summit POint came around I had three hours of track time to start the year. I worked on threshold and left foot braking techniques. My laptimes were THREE seconds faster than my previous best at Summit! This put me about 2 seconds off of the pace of the class front runners. I'm still "midpack" but running without a LSD or welded diff on a non GTI motor that's down a full point on compression and running Kumhos compared to the more expensive and faster Hoosiers that the front runners are using. What's really cool is to see your lap times drop every race with the satisfaction that it's YOU and not some magic set up. I know it sounds boring, but make sure that the car is reliable as can possibly be.That way you can be assured to finish your races and get signed off. Trust me, drving home from the track with a broken car is totally dejected feeling as well as a tremedously poor use of your racing budget. Not to get too far off of the original question here, but chance are if the car ran well before, don't change it, learn it and later on you can "find time" in the set up. I can't tell you a great set up for your car, because I'm still learning mine, but I think that advice of "fix the loose nut behind the wheel" was the best advice I've been given. JOE
