A1 Rabbit suspension Setup
Hello all, I am in the process of rebuilding my dads ITC Rabbit. The car has been in storage for 9 years and need quite a lot of work. So far I have the car running and driving and just finished all the brakes on the car. My next venture is to put suspension on the car. The car has existing Koni Yellow shocks( the right front is blown) and suspensin techniques springs and front sway bar. ( It also has a HUGE rear bar, not sure the manufacturer or size)
Anyway, I would like to continue to run the Koni Shocks and run some sort of coil-over suspension. I am going to be sending the rear shocks off to be rebuilt and re-valved depending on what spring rate I choose to run. I would also like to run double adjustable shocks in the front. I know BSI makes a shortened strut housing, and I believe so does Ground control.
What sort of suspension setups are you guys running and with what spring rates / sway bars etc. etc.etc.?
I plan on using the car mostly for Autocross and for solo 1
Thanks in advance
Brad
