Originally posted by moliver:
I have a MK1 Scirocco and am going to be installing some camber plates but now the question....Do I fab my own, use BSI, use OPM or ? What do you guys use? If I fab my own, are you just using a spherical bearing at the top or a spherical thrust bearing?
Thanks for your thoughts/experience.
Mike
I ended up making some. Used a spherical bearing on the top and a thrust bearing to carry the load below the plate. If you are buying, the Ground Control ones are very nice. I would be glad to show you my setup, since we are both in chicagoland. Heck until I weld the diff I may bring the car out to a CVO autocross or two and you can see them there too.
