I rave a ITC Rabbit and use the 205-60/13 Kumho VICTORACER with a 1/8in wheel spacer for clearance so I can get up to 3deg. negative camber with this setup. The tire edge is out to the fender. I whant to go to the ECSTA 215-50/13. Anybody have experiance with this size tire on a Rabbit in relation to the tire-fender rule as well as tire clearance with coil over springs.
Tony
ITC #0
