Originally posted by Knestis:
... I would argue for a fresh answer that allowed all different kinds of hard- and software solutions but placed limitations on functionality. Something like, "Do any dang thing you want with engine management, as long as...
** Cam timing must be as stock, relative to the crankshaft rotational position
** No additional inputs are added beyond those provided as stock (e.g., vehicle speed sensor is OK [came on my Golf] but a pitot sensor for airspeed is not)
** Parameters (inputs, maps, etc.) may not be manually controlled by the driver
** There may be no data links from the pit to the car (don't laugh)
I don't know what to do about traction control and ABS. I'm tempted, as I've stated elsewhere here, to stop worrying and accept their presence in IT.
I think that the 1st, 3rd and 4th constraints probably have merit (i.e., stock valve timing, no in-cockpit control, and no distributed computer control), but I don't see any reason at all for the second constraint (only stock inputs). Why should an older or cheaper car with fewer inputs be penalized in this manner? We should be able to add any input wires or sensors to the computer. I actually don't see any reason to limit electrical outputs either, as long as those outputs aren't controlling a variable valve timing system!
