Kill Switch location
Hi,
I need to mount a kill switch in a first gen RX7. I want it to be accessible when I am belted in. It would fit nicely in the left hand air vent, but I'm not sure if this meets the "easily accessible from outside the car" requirement in the GCR since, it would essentially be behind a lateral bar of the roll cage.
My next best option is to weld a plate above or below the lateral bar where it meets the front hoop, but this is pretty close to the steering wheel, probably less than 2" away.
Any suggestions? Will the vent mount pass inspection?
Neil
I have mine in the air vent by the door on the left side. Passes tech every year without issue. I've also seen others with the switch in the same place.
Chris Ludwig
08 ITS RX7 CenDiv
mine is in the left air vent .never had a problem with tech.
steve saney
it-7 /it-a #34
