A new timing system I am working on
Folks: This a new project that I am working on with a chip engineer who works for IBM. I will have the final prototype in hand in about a week and will be testing it on the car in mid-April. I figure I would throw the description out to you for comments and questions, recommendations, suggestions, criticisms (or orders if you like). I will have the information on my website shortly
Tom Blaney
SBMS Racing’s Total Timing System
This newly developed timing system is a compact 4 display lap timing system that is intended both for endurance and sprint racing environments. The system uses a custom 7 segment led display system with an encoded infrared beacon that can be uniquely programmed for that particular display unit. Thus eliminating false triggers from other beacons and guaranteeing accurate lap and race times thought the session. The display unit contains 3 individual HH:MM:SS:TT displays and a #### lap counter. Each display has a reset button next to the display and a remotely mounted button pad for each of the 4 displays that can be attached to the steering wheel or any convenient location. The 3 time displays work perfectly for an endurance race where total time, driver segment time and lap time are constantly shown. The driver can restart each of the displays by pressing the local or remote reset button when there is a change of driver for example or if one of the displays is being used for a segment timer for a part of the track. In a sprint race the three displays can be used to monitor prior laps or used as a segment timer. While the lap counter will show laps raced.
All of the data will be stored in the display unit and can be downloaded into a laptop in standard text or spreadsheet format. The serial port interface allows access to the units configuration and data storage.
The unit will be capable of storing up to 1000 laps of data, not the 60 or so laps of the other units. The timing beacon is a self contained waterproof unit that has the batteries fitted into the unit, or if desired a remote power source can be used. The beacon encoding will be accessible on the unit. The units will be available for deliver beginning May 2004. Final price of the unit is still being determined, but we anticipate it being in the $300 to $400 range
