Rule book says you can do any mod to the inside of the stock distributor. What about the outside? Can the vaccuum advance houseing be removed complety? Can the module be mounted to the dist in place of the vaccuum advance? Thanks Dick Elliott
It doesn't say you can so the answer is probably no to the vacuum can discard. You certainly can disable it, however.
