Anyone know where I can get a basic hand pump for fluid extraction? Basically a large syringe. Griot's has one, but at $60!! Any leads?
How about a Turkey Baster from your local WalMart/Target/K-mart (or kitchen drawer if the S/O doesn't find out!)?
Bill
Planet 6 Racing
Bill is correct; a turkey baster. Another alternative is a truck-size radiator fluid tester (I found one at an auction which is identical to a turkey baster, except it is made out of glass).
Cheers
try www.harborfreight.com
Item # 40828-4VGA
Rodney Williamson
#93 IT7
www.titaniummotorsports.com
The battery bulb filler beats the turkey baster anyday as the rubber on the TB cannot hold up to most automotive fluids. The BFB is same principle with a bigger bulb and thicker rubber which makes it easier when sucking up thicker fluids such as gear oil etc. http://Forums.ImprovedTouring.com/it/smile.gif A metal syringe type suction gun can be found at your local AutoZone, NAPA and so on for about $8.
Ray
My local autoparts store has hand held fluid pumps, just look near the heavier oils.
PaulC
