I have mine wired as described in the tech article. I actually tapped into one of the ignition coil control wires underneath the dash, but it has the same affect. I don't have any other switches in the path between the master switch and the coil. The resistor ground circuit must go to the connectors labeled 1 and the coil circuit to the connectors labeled 2. The 1 connectors are closed when the master switch is off and the 2 connectors are open.
David and Ray: Thanks for the advice and guidance. I will get out the jumper wires and try several configurations and see what works. #1 terminals are wired correctly. Just don't know where I'm getting the feed from the alternator!
