I need help in getting a good starting point in set up specs for alinement for the front and rear wheels. (Toe and Camber)1986 ITS RX7 2nd Gen
Also this will the first time I will have the car cornered weighted.
Where do I start? Even out all four coners? Make the front heavier then the front or the rear heavier then the front. I heard of the ratio of the cross corner being important. I like the car to be neutral to loose. How much does the corner weight control this?
I bought JIC shocks and struts. Ride height is a seperate adjustment from the spring weight. I think the spring rates are 500# front and 300# rear
Thanks for your imput
racecarjohn:shrug:
