A1 Clutch/tranny question
Ok, this one has me stumped. I'm putting my HP Rabbit together, and I've run into a problem w/ the clutch. When everything is bolted up, I get no resistence on the clutch arm, other than the internal spring that's on the arm. I first thought that the push rod had some how not been installed, so I pulled the tranny, and sure enough, there was the push rod. It moves when you actuate the arm, but it does not seem to be hitting the disc on the pressure plate. Swaped in another trans (4K), and still the same issue.
This is a 1.6 motor w/ a 190mm clutch/pp/flywheel (4-puck clutch, lightened flywheel). Is there any difference in the push rod for the earlier cars vs. the later cars? Maybe the plate on the pressure plate? I'm really at a loss on this one.
TIA
MARRS #25 ITB Rabbit GTI (sold)
SCCA 279608
