Originally posted by nj1266:
1. I take it that in ITS no Cold Air Intake is allowed, only a pop charger? Is that correct?
This year only, you may run a cold air intake, but only if you can fit it through an existing opening in the coachwork. Grover fabbed a 2.5" CAI that works on his car though the stock opening for the resonator in the fender well.
Starting next year, the rule has already been revised to state that the source of air must either be under the hood or the original location (or something very similar). That would eliminate any possibility of a CAI for the SE-R since the opening in the stock airbox is under the hood.
2. The Suspension rules did not make sense to me. They left me very confused. Are we allowed to run shortened coilover suspensions like the ones Truechoice and motivational makes for the SE-Rs. Or are we limited to the AGXs/Ground Control set-up?
The only limitations I can think of are:
1) You are limited to the same number or springs, same type (i.e. coils, vs. torsion bars), and the original mounting locations.
2) The limits on dampers are no coilover collars that are permanently attached or part of the damper body. No remote reservior dampers. Must attach to the original stock locations. Only two adjustments are allowed.
3. Are the strut mounting hardware supposed to be stock? I am talking about the mounting brackets, insulators, and upper spring rubber and metal seats.
Nope. That is open. It's part of the damper.
5. The GCR states that we can install/remove anti-sway bars. But can we make them thicker/thiner than stock?
Swaybars are open. I am planning on making some tubular 3-piece swaybars for Grover's SE-R and my 944 as well.
