On a 1.8 RWD (miata) STL car, what should the weight be?
2490
2490.75 lbs
or
2491
almost 100 lbs heavier than SM... yikes.
2490
2490.75 lbs
or
2491
Ok wasn't sure what sticker to put on the car, thanks.
remember if you are running STL under SM prep you post the SM weight.
Ah, right; I didn't pick up on that. Dick's absolutely correct: if you keep it completely compliant to the SM specs - including restrictor plate - you're good to go at the SM weight. But remove that plate and now you've got to meet all STL specs, including weight and the 5" ride height. - GA
Oh great, then I just have to put one weight sticker on the car and that will work for SM and STL.
Thanks guys!!
(crickets)
Wow...it ain't 150 pounds, but "damn"...
Breathe Andy... breathe...
