Hmm.
1. "Please 'run my car through the system,' because you didn't do it during the great realignment of 2006."[/b]
Here is what you might see:
- "Car was run through the process and fits current parameters"
- "Car was passed over in the reset due to lack of interest and information - please write formal proposal to CRB"
2. "Please revisit the results of the weight-setting process for my car, because you didn't use the right figures, and therefore got the wrong result."[/b]
- "The information you have provided does indeed confict with the current information on hand. Tabled for more research"
3. "Please check that the weight for my car is correct, because even though it got adjusted, it's ended up at a disadvantage because the formula is skewed against my car."[/b]
4. "Please consider changing the race weight of my car despite what the formula says it should weigh, because it can't be competitive at that weight."[/b]
5. "Please decrease the race weight of my car becaue nobody I know is beating the (insert car-to-beat here)."[/b]
6. "Please decrease the race weight of my car because I just can't seem to be competitive..."[/b]
We can already see examples of all of these arguments here, and the realignment has just been approved. The distinction between a "1" and a "4" is quickly lost in arguments, particularly when the motivating factor for any presentation might simply be a desire to get a competitive break.
If "1" is OK, what is the response when someone tosses the ITAC a "2?" Observers may not make any distinction so, if the answer's different, there's squawking. If the answer's the same, then how about a "3?"
Where does the line get drawn (he asks, showing his bias that there SHOULD in fact be one)?
K [/b]
I fully expect all the 3-6's to be put to bed. Those are comp adjustments and not what the reset was all about. 1 and 2 are either demand driven where more info will be needed or an error that should be corrected. In either case, it is VERY possible that you get a - "Car was run through the process and fits current parameters".
AB
