my RX-7 with a 12A engine is locked up tighter than a drum. When I was running it last it was running extremely rich. When I looked at the carb gas was being forced down the venturis, apparently overcoming the floats. It seemed like the fuel pressure had gone crazy and was forcing gas into the engine. Anyhow, the engine was running (barely) when this was happening. After I shut it off to investigate, the next time I tried the engine was locked solid. I don't know much about the wankel's, but I did have an old VW bus where a carb would fail every once in a while and fill a cylinder full of gas. This would lock up the engine since the gas couldn't be compressed. I would turn the engine over by hand and bleed the gas down the rings and into the crankcase. It feels like a similar deal (yes, I know the rotary doesn't have cylinders). Is it possible that a chamber has filled with gas? When I took the plugs out nothing came out. Also, the oil leve in the engine is normal.
Any help is appreciated. Thanks.
