Originally posted by Domino:
He said to make it into two pieces, split down the middle, to reduce buldging because of the compound curves of the bumper. Use black aluminum rivets to attach it. I'm actually going to use 5-6mm bolts with washers. Then for added support, use two aluminum brackets. Each one should be attached to the existing chassis bolts under the front-center of the car, aft of the bottom of the radiator. The forward piece of each bracket should then be bent into an L-shape and attached to either side of the middle-split. In essence, if you were standing at the front-center of the car and looking down through the bumper the brackets would look like an upside-down "V". Adding the brake duct holes is another step before attaching obviously. Cost of a 2'x10' role is $17. Hope the explaination is clear, I'm not a technical writer.
