This should be simple enough... but I can't figure out how to drain my Cool-Shirt.
It has "dry-breaks" and they do their jobs very well.
Any suggestions???
Todd
Any suggestions???
Todd
cool suit sells a drain kit. They also recommend to run a solution of 10:1 water and bleach
Just use two small screwdrivers to open one end to drain, one end to vent. Just poke the spring loaded stoppers open. It won't drain only because it won't vent. I'd be pretty impressed if you could actually get it all dry unless you pumped nitrogen through it for a while.
For what its worth, I had one sit for almost a year to no ill effect.
Matt
