OPM Camber plates
I installed a set of these on the front of my 86 CRX Si. I left the metal dust boot covers over my tokico adjustable shocks, and put the supplied spacer on top of that. Everything went together solid, but I have some interesting noises coming from the front now. ?? I'm wondering if leaving the covers on there is causing it.
On another note, the driver side is adjusted all the way out, and only gave my 1 degree of negative camber. The passenger side is only 1/2 of the way adjusted for the same amount. I guess My car has had some damage in it's life.
thanks for the input!
I also have the OPM camber plates on my '87 Si. The noise is coming from the plates. I put a thick rubber washer at the top of each strut (just below where it attaches to the camber plate) to absorb the noise.
Scott
