I just picked up an 020 5 speed with a Quaife LSD. What gear oil should I run? Will I need a friction modifier too?
Thanks in advance for the help!
Mark
Mark
RedLine MTL works just fine.
I use Mobil 1 synthetic gear oil in my gearbox w/ Quaife. Friction modifiers are unnecessary since the Quaife doesn't use clutch plates. I've had my gearbox together for 5 seasons and every year Harry Puckett goes through it and gives it the thumbs up. Little to no wear on anything, and have only replaced 1 synchro in 5 seasons (and it was a used one to start with). Mobil 1 is good stuff. :happy204:Quote:
Mark
Mark C
The instructions with the Quaife state no special lubricant required; use the OEM Gearbox manufacturers recommendations.
+1Quote:
