Proposal for a new class.
It is time to put the spice back into IT racing. I propose a new class to be known as Spec CVPI. These things are plentiful and can be had at give away prices. It may be a little hard to fit the roll cages around the divider between the front and back seats but I'm sure that can be worked out. That is the only allowed modification, the addition of a roll cage.
The cars have to be run with the stock seats and belts to give the drivers the true In Hot Pursuit feel. And to that end the race procedures will need a little modification. On the pace lap you must be eating a donut and have a cup of scalding hot coffee tucked between your legs while typing on an MDT. As the field comes around to the starter and the green flag waves you must throw the coffee and remainder of the donut out the passenger side window, turn on the lights and siren and transmit on the radio "car /your car number/ responding code three. As you circulate around the track you must pick up the mic at each turn and announce "turning left at turn 2" or what ever is appropriate for the current turn.
PIT manouver to complete a pass is optional.:D
