Why can't we run stock gears for later GTI/Golf?
The 1-5 gear ratios described in the ITCS for the ITB Golf are the stock ratios for the earlier cars, but the later cars had a taller 2nd from the factory. Why is the SCCA limiting us to the early box? I thought the intent was that we can only run gearing that came from the factory in the car - which both versions did.
1. Is it correct that we should be able to run a transmission that came from the factory in the car?
2. If so is how do we ask to have this fixed?
Chris
