I was advised to run ford brake fluid in my ITS RX7 so i think ill give it a shot. what do you guys suggest for clutch fluid?
thanks a lot
-matt
thanks a lot
-matt
I use left over brake fluid. IMO it's not critical. If you're boiling clutch fluid you've got huge problems!
Chris Ludwig
08 ITS RX7 CenDiv
Check the specs on the Valvoline Synthetic brake fluid for brakes and clutch. I've run it for several years without any problem whatsoever. It comes in a big bottle and is cheap but has high boiling points.
