Cold start removal on 1986 Rx-7
1986 rx-7
Can you remove the cold start thing on the motor? I have searched and cannot find anything on this...(is this considered emissions stuff?) If I can I know I have to plug some vaccuum lines and a port in the top of the motor and the intake. Can anyone run me through the steps?
2. Can I just weld up the joint in the rear suspension where it moves for the passive rear steer? (instead of buying the $40ish kit) If so how would I make sure it is lined up properly for alignment?
3. Also I was wondering if anyone knew where I could get a good cheap intake setup? Mainly for the adapter from the filter to AFM. There seems to be some difference between styles of adapters and a fair amount of price difference.
4. Anymore simple engine mods I should make? I have already eliminated the air pump and 5 and 6 port actuators.
5. And the last question for now what is the best way to remove those darn stubborn flat head screws to hold the rotors on?
Thanks for any help
