I posted something under the Honda section but thought I would post it here too.
I was sure I had seen something in the past about getting some data from the ECU into the data acq system (mine is Traqmate). The obvious candidates would be water temp, rpm, and TPS if your ECU uses these values.
Has anyone tried this or have ideas about the practicality/wisdom of doing so?
Thanks.
