Originally posted by Simon:
So when I fired it up..... bang it went on, BUT I had to spray starter fluid in to make it start, then it would stall. It would not idle, or keep running if I tried with the gas. The motor sounded very very good, loud but wouldnt keep running. I checked all wires, I believe they are in the right spot, I am pretty certain, I checked fuel pump, it has alot of pressure. I have no clue what to do! Any ideas?? Please help!!!!! I can show pics if needed.
Simon
Simon, re-check the timing, and the cam alignment. My guess is that the cam is off at least 1 tooth.
