The cage was built to GP rules so I will need to cut out the braces that go to the front strut towers but thats not too bad, and the rest will be fine for ITB. [/b]
6 main points of attachement, and two optional floor/firewall points. So yes, the strut towers must be disconnected. Also reread the doorbar wording to be sure you're ok.
Rain Tray - I cut out the rain tray, is that a no no for ITB?
I don't know what a rain tray is, but I bet you need it!
Heater Core - I removed it and blocked it off, I would have to put it back correct?
Correct!
Dash & Wiring - I removed the dash and all junk wiring and replaced it with a Fiberglass Dash. I know I
need the stock dash and every ounce of wiring. Question is am I allowed to cut the dash inorder to allow for
the A pillar cage bars and also the horizontal bar connecting the two A pillars?[/b]
yes, dash can be modified for cage installation.
Bumpers - I need to put the bumpers back on correct?
Complete.
Rear Wiper - is it ok to remove the rear wiper or would that have to go back in?
Not if a car listed on the spec line was available without it. A different trim level, for instance.
