I can’t figure out this dizzy situation. I sent my dizzy off to a fellow to have it recurved. I've used him before, I trust him, and I know others that have used him too. I asked for about 22-24 degrees advance all in at about 3k. He was not able to get that, he got 24.5 advance all in at 3k
I got the dizzy and installed it. Got the car idling at 800 RPM and set the timing with a dial back light at 8-10 degrees initial timing. Dial back is set at zero, so the light is reading actual ignition timing. I only have one timing mark, a big fat line, so this is easy. I made the timing mark and have used it for a couple of months. It was made by setting the motor at TDC and scribing a big fat line at 0. Degree wheel was used for cam/crank timing.
Alright, rev up motor to like 4k. Timing scale goes to 20 degrees and the mark is way off scale. I dial the light up to 32-34 degrees but this does not bring the pointer back to zero. I dial some more. I have to dial the light up to about 42-43 degrees, roughly, to get the pointer back to zero.
This doesn’t make sense to me. Everything I’ve ever done is set the total advance with a dial back light, but in this case it is telling me that I’ve got about 42-43 degrees of total timing, which is about 10 more than I wanted.
How can this be if the dizzy only advances about 24.5 degrees? 24.5 plus about 8-10 initial should be about 33-34, which is what I need. But that doesn’t seem to be the case. This dizzy seems to be just like my old one which is going to require like zero initial, or worse timing at ATDC, to run right on advance. This leads to poor starting and almost impossible hot starting.
Ideas?
My thoughts:
*Dizzy advance is not at 24.5 degrees as I was told
*Timing light is FUBAR
*My head is screwed up and I should be dialing back to my initial advance to get total timing, in this case dialing back to 8-10 degrees.
Ron
