new seat installed
Hi gang had friday off and it was thw coolest it has been in weeks 103' and only 20-30% humdity. So I worked on the Pinto put in the new MOMO seat that saved 12 pds! And fabbed up the pass door main hoop to center bar (per SCCA) added 5lbs! Well we are still ahead! Will take out the rear panels and weight those next! Then onto the audi/vw radaitor its a 3 row! both inlet and out are 1 1/4 same as the pinto, but are both on the right side so will have to find a hose for this. Then onto the air dam if possable its converer belt rubber really heavy 16 lbs? I think back to a aluminum one 3-4lbs. Need to check the old Konis and see about replacement or rebuild. Just tough some of you guys would like a progress report. thanks Glenn
Glenn!
Go to www.afcoracing.com They have everthing you could ever use to build a race car includeing 48" x 96" sheets of .100" thick plastic in 8 different colors. Catalogs are free and service is unrealy fast. Look on page 124. Cost is aprox $50.00 a sheet. DICK
Glenn!
What car(year-make) did the radiator come out of? Also on my other posting, DON'T get the rolled up plastic as its like a wet noodle when used as a air dam. Get the sheet and you can't tear it up. I think its ABS plastic. DICK
Dick, It is a Modine #948 it fits 1984-91 audi 100, 200's Quattros and 5000s Glenn thanks for the AFCO info looks good thanks again!
