Does anyone know of a reputable shop with a chassis dyno in or near Jacksonville Florida? TIA
Okay how about within 100 miles or so. help!
are you wanting to do the tuning or do you want some to do it for you? We use one here in longwood area. I think it is 100 bucks for the first hour then 60 for every one after.
I'm not sure what I can tune other than the timing and a/f ratio. I'm installing a new engine and want to make sure all is good before it hits the track. The a/f is my main concern.
Hi Steve,
I'm in Jax also and haven't found anyone around here to use. I believe some of the local IT guys have used Stage 6 Motorsports for dyno tuning but I haven't personally worked with them.... http://www.stage6motorsports.com/
Christian
I was not aware of what kind of computer you had. You could be tuning a motec if you wanted to. However in yoru case any dyno will do. here is a quick list of dynos in the florida region. You can look through it and find one close to you.
http://www.mustangdyne.com/LocatorPages/DynLoc_FL.htm
Thanks for the help guys I'm headed to stage 6 on friday to check the place out.
