Anyone have any pics or a write up of how them plumbed in the temp probe for the mechanical water temp gauge setup? I've seen this done several times, usually by putting a tee fitting in the heater core lines and then installing the probe in the tee. Wasn't sure if it's better to remove the stock sender in the side of the head (below the dizzy) and install the probe there instead. If so, anyone have a size of the stock, single pin sensor that is in the side of the head? If not, does anyone have a source for a tee fitting that will accomodate this application in the heater core lines?
Any and all help is greatly appreciated.
Regards,
Sam
