gear questions
Ther was a thread in the past on buying used gears for a first gen RX7. I thought it was in regards to a Suzuki or Geo front diff ring and pinion. 4.77 maybe. Does anybody have info on gear sets for this car or is Mazda comp still the only source?
Dan-o 70 IT7
The 94-02 Kia sportage front diff has 4.78 gears. The Mazda b2600 front diff uses 4.44 ratio. These are interchangeable with the 94+ miata. Make sure you use good gear oil and change after every event. These are street gears and kinda fragile. Good luck.
Chris
Googled - found this article about the interchange options for Sportage gear sets.
http://www.turbomagazine.com/tech/08...ech/index.html
That is so cool... Im hittin the junk yards monday. Look at the number and options available for U-Pick it peaple. 25 bucks and all you can carry thru the gate. We are there.:cool:
Stephenb look at this post and read the article about gears.turbo magazine
The article states that the rx-8 4.44 gear is the same. Unfortunately it isn't. :(
