* Why can't you resize cracked-cap rods? What's to keep you from doing a normal resize and installing ARP rod bolts? I know what they are, but I've never worked with them.
There is no flat surface to remove material from the cap and then resize the hole. When the cap is cracked off it leaves a jagged surface that interfaces with the mirror of it's self on the rod. Just for conversations sake, the Neon does use these, and yes I am still using stock rods. Currently they are available, but only for a short time longer.
