I have had a Quaife installed and after
Two solo 1 events and two solo 2 events
I have alot of wear on the drivers side
and very little on the otherside.
Is this normal wear? http://Forums.ImprovedTouring.com/it/frown.gif
Is this on a clockwise or counter-clockwise track (or tracks)? Is that likely to have been a factor?
Kirk
both ways.
the wear on the driversside is 3x that on the
right,
Spike,
I would be looking at something other than your diff for tire wear like that. What kind of negative camber are you running?
How about toe?
drew
I was going to check toe & camber this weekend.
But when I set up the car I had 1/8 total
toe out and 2.5* camber.
I thought about that at first but after looking at the amount of wear and the amount
of use I think there might be something wrong with my Quaife.
It's as I only have one wheel drive.
Thanks for you help
Spike
