Suggestions requested - trailer lighting
I have an open trailer for the race car, old utility trailer with aluminum ramps. Rewired new rear lamps last year, and with a four pole connector, everything worked just fine.
This year, I added the wheel well clearance lights (trailer was born before they were required) and the three light bar on the back end. Hooked all the wires I put in last year to a terminal box. And now when I apply voltage to any connector in the box, I get nothing.
Here is my plan. Since I have plenty of new wire, I would start from the terminal box and run the wires from the hitch to the rear - one pair for each side, brown/yellow and brown/green. At each pint where I need to splice in a lamp (such as the yellow side marker light, combination yellow/red clearance marker, red three lamp bar...) I would cut the insulation on the long brown wire, splice without cutting the long wire, and insulate - testing for continuity and power at each splice before insulating. With this plan, I will be testing at each change before going on to the next.
Anyone see anything wrong with this plan, or can add any helpful hints?
Thanks.
Bill Stevens
Mbr 103106
BnS Racing
83 ITA Shelby Dodge Charger
