Hey Guys, What cold pressures should I start with for an ITS 240sx running the Hoosiers? What about hot pressures? Temps?
Go to the Hoosier website and get the tire care information. They offer cold pressures based on vehicle weight. I use 33f and 32r as a starting point on my 2750lb 240sx and look for them to build to about 42lbs hot.
I used to start at 30lbs but found that going 2 lbs higher was better same as Joe. Joe are you going to send me that info for EP
