This post does not really fall under Tech - Engine or Tech Electronic, so I'm placing it here! :P
This years' addition to 17.27 requires that all terminals on the master switch be insulated. I could not find terminal boots that would fit in either Advanced Auto Parts or Auto Zone, so I installed the boots from Pegasus ($2.49 each). Installation took about 10 minutes and they look great. Did not even have to take the ends off the cable.
This takes care of the large terminals. The smaller terminals, I just wrapped with insulating tape.
Go to a wholesale plumbing supply house/store. Get the splice kit for well pumps. Lots of different types. You want the heat srink type with Goop of somekind inside the sleave. Last three days longer than a rock. Down side is it take three men and a boy to remove it,but it wont let water/gas get to the wires.
