<font face="Verdana, Arial" size="2">...I do have spark at the coil and to the coil wire to the top of the distributor...</font>
Hold it right there, Pard: you say you *are* getting spark out the top of the coil? If so, yer problem ain't the Hall Effect system. If Mr. Sparky is getting out of the coil, but not inta the spark plugs, the problem is in the highway between that there coil wire and the spark plug. I'd be a-checkin' the coil lead wire, cap, rotor, spark plug leads, and the spark plugs...
