steering arm joint 'sticking'
Awhile back I was checking my alignment, and noticed that as I was doing the 'tape measure' alignment, the closer I tried to get to 0 toe, the farther I got...
then I realized that the steering arm was unscrewing itself from the steering rack while I was turning the arm into the tie-rod end. So I pulled off the rack boot and voila, noticed the locknut was not tight against the joint that threads onto the steering rack. It seems that when I was turning the steering rod to thread it 'into' the tie-rod end, it was threading itself 'off of' the rack.
Anyway, I pulled off the arm which are new on both sides, and tried to move the joint... it was almost impossible unless I really twisted at it. Um, this isn't suppose to be this tight, right?, even for a new arm? I even regreased it and tried to work some of the grease into it, but it was still very tight. Same for the other side.
I can't imagine how this might be affecting my handling, but is there any easy way to break these in, or get them loosened up - at least for alignment's sake?
PJ
83 Rabbit GTI - future ITB
