Originally Posted by
Ron Earp
Hi Dan,
I think you'll find the cars will put down around 250-270 ft-lbs at the wheel on a Dynojet. This isn't that far off the latest 300zx ITR build that made 252 ft-lbs at the wheel on a Dynojet. The Pony cars weigh more than the 300zx in the proposal, have much smaller brakes, a less sophisicated suspension (a solid rear axle), and some of the cars have rear drum brakes.
Of course, dyno results are hard to compare, but you've got 2 valve pushrod OHV motors motors with low compression and high torque competeting against 4 valve DOHC motors that make a bit less torque, but similar or more, power.
Fortunately when the cars are classed more than just one outstanding feature of the car is considered. Power, torque, suspension, brakes, etc. are under review. While the Pony cars have great torque, they are not ITR class leaders in the other areas.
As far as the comparison to AS - for those guys that think IT prep is anything like AS, please read the AS rules set. There is no comparison between the two - non stock cylinder heads, any cam to .500" lift, tubular arms, Ford 9" rears for everyone, Holley carbs for everyone, port all you like, high hp intakes, and so on. Two different worlds. There are many GM/Ford faithful that would like the chance to run a V8 Pony car with a cheap, inexpensive, non-national, and competitive IT ruleset.
Ron
