I run a Porsche 924 that runs on the same Bosche CIS fuel injection system. I am in search of an external fuel pump that is also found on VW Rabbits. Does anyone know where I can find one of these as OEM?
Jeremy
Jeremy
You can get a used VW one at a great price from our sponsor force5auto.com. Chris (the Owner) might also have a good source with good deals on new ones also. If not we could probably get you a good deal on a vw one from the dealer... other than that any parts store should have remahn ones for sale.
How about a good place to find one that is not a "gravity feed" like most VW and/or Audi's??? One that delivers enough PSI for the CIS...
Raymond
Raymond, I'll check out that site. Thanks for the tip. The fuel pumps on the 924 pump a lot of PSI, but are painfully expensive to replace http://Forum.ImprovedTouring.com/it/frown.gif They go for around $200 new. I was told that their may be a cheaper pump that works on Rabbits as well as Porsches.
Thanks for the reply.
Jeremy
Jeremy,
A new high-pressure Bosch pump for a VW w/ CIS will run you about the same. While I haven't looked at the part #'s, I can't believe there's much difference in the VW pump vs. the Porsche pump.
SCCA 279608
