Any suggestions as to what Brand of Ignition coils to use? The coils on car now "Blue". I haven't pulled then yet as I would rather have replacements in hand. Thanks Tom weaver ITA # 63
i use the original coils have no problems with them. also the MSD blaster coils that fits in the original holder work just as good.
steve saney
it-7 /it-a #34
I use the MSD Blasters. I was told to use the off-road version, but I forget the reason.
The MSD coil recommend for sideways mounting is the "vibration resiatant" coil. This coil is epoxy filled, rather than oil filled, as the conventional "blaster" coil is.
When a oil filled coil designed for vertical mounting is mounted on it's side, it is theoretically possible for the coil to overheat and fail.
Did I forget to mention this in my "ignition" post I wrote several months ago?
Oh well, do a search under my username if you want to read it.
Rodney Williamson
#93 IT7
Titanium Motorsports temporally move to:
http://bellsouthpwp.net/t/a/tamrod93/
